Filtering and forcing DSCP values (IPv6 ACLs)
In IPv6 extended ACL rules, re-marking (forcing) DSCP values can change priority on egress traffic, by which you can prioritize ingress traffic. You can also filter IPv6 packets by DSCP value.
  1. Enter configure terminal to access global configuration mode.
    device# configure terminal
  2. Enter the ipv6 access-list extended command to create or access the ACL.
    device(config)# ipv6 access-list extended ipv6_acl_1
  3. To filter incoming packets by DSCP value, define permit or deny rules specifying the dscp parameters.
    device(conf-ip6acl-ext)# seq 10 deny ipv6 2001:2002:1234:1::/64 2001:1001:1234:1::/64 dscp 25 count
    device(conf-ip6acl-ext)# seq 20 permit ipv6 2001:2002:2345:1::/64 any dscp 20 count
  4. To re-mark the DSCP value of incoming packets, define permit rules specifying the dscp-force parameters.
    device(conf-ip6acl-ext)# seq 30 permit ipv6 2001:2002:2346:1::/64 any dscp-force 10
  5. Apply the ACL that you created to the appropriate interface.
    device(config)# interface ethernet 2/2
    device(conf-if-eth-2/2)# ipv6 access-group ipv6_acl_1 in
