The "no" form of the
	 ssh server cipher and
	 ssh client cipher commands sets the SSH ciphers back to the default algorithms.
		  Enter global configuration mode.
			 device# configure terminal
				Use the ssh server cipher
					command to remove the server cipher for SSH.
				You can remove multiple ciphers
					by separating the string names with commas.
					device(config)# no ssh server cipher
				Use the ssh client cipher
					command to remove the client cipher for SSH.
					device(config)# no ssh client cipher
