Implementation flows for rACLs and interface ACLs
The implementation flows for Layer 3 interface ACLs and receive-path ACLs (rACLs) are similar.
The following table displays the differential
flows of implementation topics for Layer 3 interface ACLs and rACLs:
The above table indicates that there are no
structural differences between Layer 3 interface ACLs and rACLs; you use identical
procedures for all types. The implementation differences are as follows:
- You apply interface ACLs from an
interface (including VE) configuration mode, using the {
ip
ipv6
access-group
command.
- You apply rACLs from global
ip
ipv6
receive
access-group command.
- Mirroring is not supported for
rACLs.
