Use this procedure to apply an IPv4 or IPv6 ACL to a LAG (logical) interface.
Enter the configure terminal
command to access global configuration mode.
device# configure terminal
Enter the
interface port-channel command, specifying the port-channel number.
device(config)# interface port-channel 10
Enter the ip/ipv6
access-group command, specifying the ACL that you are applying to
the interface.
- For IPv4 ACLs, specify the
ingress or egress direction.
device(config-Port-channel-10)# ip access-group test_02 out
- ( SLX 9150, or SLX 9250 devices) For IPv6 ACLs, specify the ingress direction.
device(config-Port-channel-10)# ipv6 access-group stdV6ACL_1 in
- ( SLX 9540 or SLX 9640 devices) For IPv6 ACLs, specify the ingress or egress
direction.
device(config-Port-channel-10)# ipv6 access-group stdV6ACL_1 out
