Disable key pairs and trust points for HTTPS cryptography certificates, which disables the HTTPS security protocol.
To shutdown the HTTPS service without disabling the HTTPS certificates, execute the http server shutdown command.
When the Apache (web server) boots. it enables HTTPS service only in the presence of HTTPS crypto certificates.
HTTP and HTTPS are mutually exclusive.
HTTPS certificates must be configured and enabled for web service to function on the device.device# no crypto ca import t1 certificate cert-type https device# show crypto ca certificates Trustpoint: t1 certificate: none CA certificate: SHA1 Fingerprint=76:5B:D4:2C:CB:54:FE:6B:C5:E0:E3:FD:11:B0:88:70:80:12:C6:63 Subject: C=US, ST=CA, L=SJ, O=BR, OU=SF, CN=SOUND/emailAddress=sravi Issuer: C=US, ST=CA, L=SJ, O=BR, OU=SF, CN=SOUND/emailAddress=sravi Not Before: Sep 19 20:56:49 2014 GMT Not After : Oct 19 20:56:49 2014 GMT purposes: sslserver
device# no crypto ca authenticate t1 cert-type https device# show crypto ca certificates Certificate Type: none; Trustpoint: t1 Certificate: none CA certificate(Client authentication): none CA certificate(Server authentication): none
device#configure terminal
device(config)# crypto ca trustpoint t1 device(config-ca-t1)#no keypair device(config-ca-t1)# do show running-config crypto crypto key label k1 rsa modulus 2048 crypto ca trustpoint t1 ! ! device(config-ca-t1)# do show crypto ca trustpoint Trustpoint: t1; Key-pair: none
device(config)# no crypto ca trustpoint t1 device(config-ca-t1)# do show running-config crypto crypto key label k1 rsa modulus 2048 ! device# show crypto ca trustpoint Trustpoint: none; Key-pair: none
device(config-ca-t1)# exit device(config)#no crypto key label k1 device(config)# do show running-config crypto % No entries found. device(config)# do show crypto key mypubkey key label: none key type: none key size: none
