Layer 3 ACL configuration guidelines
We present configuration guidelines for all ACLs, then for Layer 3 ACLs, then for L3 ACLs applied to a user interface, then for ACLs applied to the management interface, and then guidelines for receive-path ACLs (rACLs).
k
The following guidelines are for all ACLs:
Guidelines for all Layer 3 ACLs
(All supported devices) In addition to the guidelines that apply to all ACLs, the following guidelines are relevant for Layer 3 ACLs:
  • In ingress Layer 3 ACLs, hard-drop rules affect control protocol and MY IP packets.
  • On Management interfaces, a hard-drop works the same as a denyaction.
  • Although L3 ACL deny rules do not drop protocol packets, best practice is to define an explicit permit rule for needed protocols.
( SLX 9150, and SLX 9250 devices) The following additional guidelines are relevant for Layer 3 ACLs:
  • For tunnel-termination cases, ingress ACLs are applicable for inner headers.
  • For tunnel-origination cases, egress ACLs are applicable for outer headers.
( SLX 9540 and SLX 9640 devices) The following additional guidelines are relevant for Layer 3 ACLs:
  • In egress Layer 3 ACLs, deny and hard-drop rules do not affect control protocol and MY IP packets.
Guidelines for Layer 3 ACLs applied to user interfaces
(All supported devices) In addition to the previous guidelines, the following guidelines are relevant for Layer 3 ACLs applied to user interfaces:
  • There is an implicit "deny" rule at the end of every Layer 3 ACL applied to a user interface. This denies all L3 streams that do not match any of the configured rules in the ACL.
  • Traffic generated by the CPU—for example, echo request packets—are not filtered by egress IPv4 ACLs.
( SLX 9540 and SLX 9640 devices) In addition to the previous guidelines, the following guidelines are relevant for Layer 3 ACLs applied to user interfaces:
  • Egress IPv4 ACLs are applicable only for routed traffic.
Guidelines for ACLs applied to the management interface
The following protection guards against malicious ICMP timestamp requests (icmp-type 13):
  • ICMP timestamp requests and responses are dropped by default.
  • If an ACL with a permit icmp any any rule is applied to the management interface, such a rule permits ICMP timestamp requests. However, ICMP timestamp responses are blocked.
The following additional guidelines are relevant for Layer 3 ACLs applied to the management interface:
If no ACLs are applied to the device management interface, ICMP pings are allowed. In addition, the following default rules are effective:
  • seq 0 permit tcp any any eq 22
  • seq 1 permit tcp any any eq 23
  • seq 2 permit tcp any any eq 80
  • seq 3 permit tcp any any eq 443
  • seq 4 permit udp any any eq 161
  • seq 5 permit udp any any eq 123
  • seq 6 permit tcp any any range 600-65535
  • seq 7 permit udp any any range 600-65535
Guidelines for rACLs
(All supported devices) The following additional guidelines are relevant for all receive-path ACLs (rACLs):
  • Interface ACLs and rACLs share the same resource (database-table).
  • In all rACLs, explicit and implicit rules are processed in the following order:
    1. Explicit rules, in an order determined by their seq numbers.
    2. An implicit deny any my-ip rule that affects all other CPU-bound traffic.
  • Under inband management, you need to include permit rules for your telnet/SSH access to the device.
( SLX 9150, and SLX 9250 devices) The following additional guidelines are relevant for all receive-path ACLs (rACLs):
  • IPv4 rACLs apply to multicast datapath traffic only if multicast destination-IPs are explicitly specified in rules.
  • In an IPv4 rACL rule, if a destination IP is not specified, my-ip (IP addresses configured on any Layer 3 interface) is interpreted as the destination IP. Such rules do not filter multicast traffic.
  • Multicast traffic is first filtered by rACLs, then by interface ACLs.
( SLX 9540 and SLX 9640 devices) The following additional guidelines are relevant for all receive-path ACLs (rACLs):
  • rACLS are supported only for unicast, routed traffic.
  • In an IPv4 rACL rule, if a destination IP is not specified, matches apply to all IP addresses configured on the device.
(All supported devices) The following guidelines are relevant for multiple rACLs:
  • Multiple rACLs are supported only in the default TCAM profile.
  • You can apply a maximum of 400 receive-path ACLs to a device, as follows:
    • 200 IPv4 receive-path ACLs
    • 200 IPv6 receive-path ACLs
  • Supported sequence numbers for rACLs range from 1 through 2047.
  • If you apply an rACL to a device without specifying a sequence number, numbers are assigned automatically, as follows:
    • The first rACL applied to the device is assigned 10.
    • Each additional rACL applied is assigned an increment of 10 above the highest applied sequence number.
The following table compares the effect of deny or hard-drop rACL matches for different types of packets.
Table 1. Effect of deny and hard-drop matches on different packet types
Packet type Deny or hard-drop match
Control packets
Not dropped
Data packets
NA
My IP packets (incl. ICMP, control or data)
Dropped
