You can configure the lockout threshold with the password-attributes max-retry maxretry command. The value of the maxretry specifies the number of times a user can attempt to log in with an incorrect password before the account is locked. The number of failed login attempts is counted from the last successful login. The maxretry can be set to a value from 0 through 16. A value of 0 disables the lockout mechanism (default).
The following example sets the lockout threshold to 5.
device# configure terminal Entering configuration mode terminal device(config)# password-attributes max-retry 4
When a user account is locked, it can be unlocked using the procedure described in Unlocking an account.
