The following procedure resets the login configuration mode to the default value using the
no aaa authentication login command.
In privileged EXEC mode, use the
configure terminal command to enter global configuration mode.
device# configure terminal
Entering configuration mode terminal
Enter the
no aaa authentication login command to remove the configured authentication sequence and to restore the default value (Local only).
device(config)# no aaa authentication login
Verify the configuration with the
do show running-config aaa command.
device(config)# do show running-config aaa
aaa authentication login local
Log in to the device using an account with TACACS+-only credentials. The login should fail with an "access denied" error.
Log in to the device using an account with local-only credentials. The login should succeed.
