Applying a bACL to a VE interface
Use this procedure to apply an IP broadcast ACL (bACL) to a VE interface (attached to a VLAN).
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the interface ve command, specifying the vlan-id.
    device(config)# interface ve 50
  3. Enter the ip subnet-broadcast-acl command, specifying the bACL that you are applying to the VE.
    device(config-ve-50)# ip subnet-broadcast-acl bacl_20
