This task enables Raslog messages for ACL rules with log keywords and specifies how long the system waits between ACL Raslog messages.
For details of Raslog messages, refer to the Extreme SLX-OS Message Reference.
device# configure terminal
device(config)# acl-policy
device(config-acl-policy)# acl-log-raslog
device(config-acl-policy)# acl-log-raslog log-interval 8
The following output is an ACL Raslog example.
MAC ACL mac_2 permitted 1 packets on intf eth1/6 [SA:0010.1010.1001, DA:0001.0300.0500, Type:0, VLAN:101, SIP:0.0.0.0, DIP:0.0.0.0, l3_proto:none, src_port:0, dst_port:0] IP ACL v4acl denied 1 packets on intf eth1/6 [SA:0001.0300.0400,DA:0001.0300.0500, Type:800, VLAN:100, SIP:2.2.2.2, DIP:6.6.6.6, l3_proto:udp, src_port:66, dst_port:77] IPv6 ACL v6acl permitted 1 packets on intf po44 [SA:0001.0300.0400,DA:0001.0300.0500, Type:86dd, VLAN:100, SIP:fe80::201:3ff:fe00:400, DIP:3555:5555:6666:6666:7777:7777:8888:8888, l3_proto:udp, src_port:63, dst_port:63]
