Deleting a rule
  1. In privileged EXEC mode, use the configure terminal command to enter global configuration mode.
    device# configure terminal
    Entering configuration mode terminal
  2. Enter the no rule command followed by the index number of the rule you wish to delete.
    device(config)# no rule 155
    After rule 155 is deleted, the SecAdminUser can no longer access the role command.
