Viewing the TACACS+ accounting logs
The following excerpts from TACACS+ accounting logs exemplify typical success and failure cases for command accounting and login accounting.
The following examples were taken from the free TACACS+ server. The order of the attributes might vary depending on the server package, but the values are the same. The location of the accounting logs depends on the server configuration.
Command accounting examples
The following example shows a successful execution of the shutdown command by the admin user, followed by a no shutdown command.
Wed Oct 14 10:40:40 2015        10.18.245.157   admin1  /dev/pts/0      10.70.7.36      stop    task_id=1       timezone=Etc/GMT        service=shell   priv-lvl=0      Cmd="operational top configure terminal" Stop_time=Wed Oct 14 17:39:49 2015
        Status=Succeeded
Wed Oct 14 10:42:14 2015        10.18.245.157   admin1  /dev/pts/0      10.70.7.36      stop    task_id=1       timezone=Etc/GMT        service=shell   priv-lvl=0      Cmd="configure conf-if-eth-0/3 shutdown"      Stop_time=Wed Oct 14 17:41:24 2015
        Status=Succeeded
Wed Oct 14 10:42:23 2015        10.18.245.157   admin1  /dev/pts/0      10.70.7.36      stop    task_id=1       timezone=Etc/GMT        service=shell   priv-lvl=0      Cmd="configure conf-if-eth-0/3 no shutdown"   Stop_time=Wed Oct 14 17:41:33 2015
The following example shows a successful execution of the username command by the admin user.
<102> 2012-04-09 15:21:43 4/9/2012 3:21:43 PM NAS_IP=10.17.37.150 Port=0 rem_addr=Console User=admin Flags=Stop task_id=1 timezone=Etc/GMT+0 service=shell priv-lvl=0 Cmd=username Stop_time=Mon Apr 9 09:43:56 2012
 Status=Succeeded
The following example shows a failed execution of the radius-server command by the admin user due to an invalid host name or server IP address.
Aug 19 20:57:12 10.24.12.77     admin   /dev/pts/0      10.252.200.38   stop    task_id=1       timezone=Etc/ config radius-server host 10.2.3"      Stop_time=Fri Aug 19 08:25:56 2016
        Status=%% Error: Invalid host name or IP address
Login (EXEC) accounting examples
The following example shows a successful login of the trial user.
Aug 19 21:01:46 10.24.12.77     user    /dev/pts/1      10.252.200.38   start   task_id=1       timezone=Etc/GMT     service=shell
The following example shows a successful logout of the trial user.
Aug 19 21:03:11 10.24.12.77     user    /dev/pts/1      10.252.200.38   stop    task_id=1       timezone=Etc/GMT     service=shell   elapsed_time=85 reason=admin reset
