The following procedure configures TACACS+ as the primary source of authentication and the device-local user database as the secondary source. For complete information on login authentication mode, refer to the aaa authentication login command in the Extreme SLX-OS Command Reference.
device# configure terminal Entering configuration mode terminal
device(config)# aaa authentication login tacacs+ local
device(config)# do show running-config aaa aaa authentication login tacacs+ local
