In this example, traffic is routed from different sources to different places (next hops). Packets arriving from source 192.168.0.0 are sent to the VRF vroutefwd‘s next hop at 3.3.3.3; packets arriving from source 192.168.1.1 are sent to the VRF vroutefwd‘s next hop at 3.3.3.5.
device(config)# ip access-list standard Jules device(conf-ipacl-std)# permit 192.168.0.0 255.255.255.0 device(conf-ipacl-std)# exit device(config)# ip access-list standard Vincent device(conf-ipacl-std)# permit 192.168.1.1 255.255.255.0 device(conf-ipacl-std)# exit
device(config)# route-map pulp_fiction permit 10 device(config-routemap-pulp_fiction/permit/10)# match ip address acl Jules device(config-routemap-pulp_fiction/permit/10)# set ip vrf vroutefwd next-hop 3.3.3.3 device(config-routemap-pulp_fiction/permit/10)# exit
device(config)# route-map pulp_fiction permit 20 device(config-routemap-pulp_fiction/permit/20)# match ip address acl Vincent device(config-routemap-pulp_fiction/permit/20)# set ip vrf vroutefwd next-hop 3.3.3.5 device(config-routemap-pulp_fiction/permit/20)# set ip next-hop 6.6.6.7 device(config-routemap-pulp_fiction/permit/20)# exit
device(config)# interface ethernet 1/1 device(conf-if-eth-1/1)# ip policy route-map pulp_fiction
