Configuring TACACS+ for the AAA user role
Configuring TACACS+ for the AAA user role allows the AAA user role to access configuration commands.
At least one TACACS+ server must be configured on the device using the tacacs-server host command.
You must configure a server-side user role on the TACACS+ server. Refer to Configuring TACACS+ for a mixed-vendor environment for more information.
The following example assigns the user "Agnes" a single password for all types of login authentication.
user = Agnes {
global = cleartext "Agnes global password"
