Rules for interface commands
Rules can be created for a specific instance of the interface-related configuration commands.
By default, every role has the permission to read the configuration data related to all the instances of the interfaces using the
show running-config interface command.
The following rules govern interface commands:
- If a role has a rule with a
read-write operation and the
accept action for only a particular instance of the interface, users associated with this role can only modify the attributes of that instance.
read-only operation and the
accept action for only a particular instance of the interface, users associated with this role can only read (using the
show running-config command) the data related to that instance of the interface.
- If a role has a rule with a read-write
operation and the reject action for only
a particular instance of the interface, users associated with this role cannot
execute and read the configuration data for that interface instance.
In the following example, the
rules are applicable only to a particular instance of the specified interface.
device(config)# rule 60 action accept operation read-write role NetworkAdmin command interface ethernet 1/4
device(config)# rule 65 action accept operation read-write role NetworkAdmin command interface port-channel 2
device(config)# rule 68 role NetworkAdmin action reject command interface ethernet 3/4
- If a role has a rule with a read-only
or read-write operation and the reject action for an
interface or an instance of the interface, users associated with this role cannot
perform clear and
show
operations related to those interfaces or interface instances. To perform clear and show operations, the
user‘s role must have at least read-only and the
accept permission. By default, every role has the read-only
and accept permission for all interface instances.
NetworkAdmin users cannot perform
clear and
show operations
related to all
ethernet instances.
device(config)# rule 30 action accept operation read-write role NetworkAdmin command interface ethernet
- If a role
has a rule with read-only or read-write operation,
and the reject action for an interface ethernet instances,
users associated with this role cannot perform clear and show operations related
to those instances. To perform clear and show operations related
to interface
ethernet instances, the role should have at least read-only and accept
permission. By default, every role has the read-only or accept
In the following example, users
associated with the NetworkAdmin role cannot perform some of the clear and show operations
related to all ethernet instances.
device(config)# rule 30 role NetworkAdmin action reject command interface ethernet
- The dot1x option under the
interface instance submode can only be configured if the role has the
read-write and accept permissions for
both the dot1x
command and interface instances.
associated with the CfgAdmin role can access and execute the
dot1x command in
ethernet instances.
device(config)# rule 16 action accept operation read-write role cfgadmin command interface ethernet
device(config)# rule 17 action accept operation read-write role cfgadmin command dot1x
