Configuration guidelines for bACLs
The configuration considerations for bACLs
are as follows:
- You can apply no more than one bACL at
device level.
- You can apply no more than one bACL to an
interface or VE.
- bACLs applied at device level filter
traffic both on default-VRF and user-vrf interfaces.
- If a physical port is a member of a
virtual interface, then ACL binding is permitted only at the VE level and not at the
physical port level.
- If bACLs are applied both at device level
and at interface- or VE-level, a match at interface- or VE-level takes precedence over a
match at device level.
- For LAG ports, all ports within the LAG
must have the same IP broadcast ACL applied to them before the LAG is created. On deleting
the LAG, the IP broadcast ACL binding is replicated on all individual LAG ports.
IP directed-broadcast ACL binding is not be permitted on VPLS and VLL endpoints.
- IP tunnel interfaces are not supported.
- Because ingress traffic matching bACLs is
not subject to security ACLs or RL-ACLs, configure bACLs so that only directed broadcast
traffic matches the bACL permit/deny/hard-drop rules.
- bACLs do not support ACL-based logging,
Sample Flow (sFlow), or mirroring.
- Traffic matching bACLs is not subject to
policy-based routing (PBR).
- CAM sharing is not supported for bACLs.
- Broadcast ACLs do not filter /31
addresses—because the /31-subnet supports only two unicast addresses.
- When ACLs of multiple types are applied,
processing priority is as follows: bACLs > rACLs > PBR > Layer 3 ACLs > Layer 2
ACLs. However, if any filter has a drop match, the packet is dropped irrespective of the
priority.
- When ACLs
of multiple types are applied, processing priority is as follows: bACLs > rACLs > PBR
> Layer 3 ACLs > Layer 2 ACLs > UDAs. However, if any filter has a drop match, the
packet is dropped irrespective of the priority.
