The following steps configure an IPv4 PBR by setting NULL0 interface as the next hop in the route map.
device# configure terminal
device(config)# ip access-list standard 99 device(conf-ipacl-std)# permit 192.168.0.0 255.255.255.0
device(conf-ipacl-std)# exit
device(config)# route-map test-route permit 99
device(config-route-map-test-route/permit/99)# match ip address acl 99
device(config-route-map-test-route/permit/99)# set ip interface null0
device(config-routemap-test-route/permit/99)# exit
device(config)# interface ethernet 1/1
device(conf-if-eth-1/1)# ip policy route-map test-route
The following example shows the configuration steps to configure an IPv4 PBR to send all traffic from 10.157.23.0 0.0.0.255 to the null interface, thus dropping the traffic instead of forwarding it.
device# configure terminal device(config)# evice(config)# ip access-list standard 99 device(conf-ipacl-std)# permit 10.157.23.0 0.0.0.255 device(conf-ipacl-std)# exit device(config)# route-map test-route permit 99 device(config-route-map-test-route/permit/99)# match ip address acl 99 device(config-route-map-test-route/permit/99)# set ip interface null0 device(config-route-map-test-route/permit/99)# exit device(config)# interface ethernet 1/1 device(conf-if-eth-1/1)# ip policy route-map test-route device(conf-if-eth-1/1)# end
