Entering the no form of the password-attributes command resets all password attributes to their default values. If you specify a specific attribute, only that attribute is reset to the default. If you enter no password-attributes without operands, all password attributes are reset to their default values.
device# configure terminal Entering configuration mode terminal device(config)# no password-attributes min-length device(config)# password-attributes max-retry 4 device(config)# no password-attributes numeric
