Use the command line to configure the Secure Shell (SSH) ciphers.
device# configure terminal
device(config)# ssh server cipher aes192-cbc,aes128-ctr
device(config)# ssh client cipher aes192-cbc,aes128-ctr
device(config)# do ssh-server restart Warning: This operation will disconnect all active SSH sessions. Are you sure you want to restart the SSH server [y/n]? y SSH server is going down for restart NOW !! SSH server restarted !!
device(config)# do show running-config ssh server cipher ssh server cipher aes192-cbc,aes128-ctr device(config)# do show running-config ssh client cipher ssh client cipher aes192-cbc,aes128-ctr device(config)# do show ssh server status SSH Server Rekey Volume: 1024 SSH Server Auth Tries: 6 SSH Server Login Timeout: 120 VRF-Name: mgmt-vrf Status: Enabled VRF-Name: default-vrf Status: Enabled device(config)# do show ssh client status SSH Client Cipher: aes192-cbc,aes128-ctr
device(config)# ssh server cipher ? Possible completions: <string> Ciphers supported :- aes128-ctr, aes192-ctr, aes256-ctr, aes128-cbc, aes192-cbc, aes256-cbc, aes128-gcm@openssh.com, aes256-gcm@openssh.com,3des-cbc,blowfish-cbc,cast128-cbc,arcfour, arcfour128, arcfour256, rijndael-cbc@lysator.liu.se, chacha20-poly1305@openssh.com. Ciphers recommended in FIPS mode :- aes128-ctr, aes192-ctr, aes256-ctr, aes128-cbc, aes192-cbc, aes256-cbc. Configuring anything else is a security risk. Ciphers recommended in CC mode :- aes128-ctr, aes256-ctr, aes128-cbc, aes256-cbc. Configuring anything else is a security risk. device(config)# ssh client cipher ? Possible completions: <string> Ciphers supported :- aes128-ctr, aes192-ctr, aes256-ctr, aes128-cbc, aes192-cbc, aes256-cbc, aes128-gcm@openssh.com, aes256-gcm@openssh.com,3des-cbc,blowfish-cbc,cast128-cbc,arcfour, arcfour128, arcfour256, rijndael-cbc@lysator.liu.se, chacha20-poly1305@openssh.com. Ciphers recommended in FIPS mode :- aes128-ctr, aes192-ctr, aes256-ctr, aes128-cbc, aes192-cbc, aes256-cbc. Configuring anything else is a security risk. Ciphers recommended in CC mode :- aes128-ctr, aes256-ctr, aes128-cbc, aes256-cbc. Configuring anything else is a security risk.
