Changing the LDAP server parameters follows the same procedure as that noted for adding an LDAP server to the client server list. Enter the host IP address or host name, and then enter the new values as required.
Refer to Adding an LDAP server to the client server list.
device# configure terminal Entering configuration mode terminal device(config)# ldap-server host 10.24.65.6 device(config-host-10.24.65.6/mgmt-vrf)# basedn security.brocade.com
