Default accounts and roles
The software ships with two default accounts—admin and user—and two corresponding default roles:
- admin—Accounts with admin permissions can execute all commands supported on the device. (For the initial admin login, refer to the relevant
Hardware Installation Guide.)
- user—Accounts with
user-level permissions can execute all show commands supported
on the device. User-level accounts can also execute the following operational
commands: cfm,
execute-script, exit, mtrace, no, ping, rasman, ssh, sysmon, telnet, timestamp, trace-l2, and traceroute.
For details on non-default roles (also known as
user-defined roles), refer to
User-defined roles.
