You can set the authentication mode with the aaa authentication login command.
You can reset the configuration to the default value using the no aaa authentication login command.
In a configuration with primary and secondary sources of authentication, the primary mode cannot be modified alone. First remove the existing configuration and then configure it to the required configuration.device# configure terminal Entering configuration mode terminal
device(config)# aaa authentication login radius local ** or ** device(config)# aaa authentication login tacacs+ local
device(config)# do show running-config aaa aaa authentication login radius local
