When you create ACL rules for which you want to enable logging, you must include the log parameter.
device# configure terminal
device(config)# ip access-list standard ip_acl_1
device(conf-ipacl-std)# seq 5 permit host 10.20.33.4 log
device# show access-list-log buffer Frames Logged on interface 2/1 : -------------------------------- Frame Received Time : Fri Dec 9 3:8:48 2011 Ethernet, Src : (00:34:56:78:0a:ab), Dst: (00:12:ab:54:67:da) Ethtype : 0x8100 Vlan tag type : 0x800 VlanID : 0x1 Internet proto, Src : 192.85.1.2, Dst: 192.0.0.1 Interface : Type of service : 0 Length : 110 Identification : 0 Fragmentation : 00 00 TTL : 255 protocol : 253 Checksum : 39 3a Payload type : packet(s) repeated : 30 Ingress Deny Logged
If an ACL with rules that contain the log keyword is applied to the management interface, logs are not recorded for that ACL.
