FreeRADIUS is an open source RADIUS server that runs on all versions of Linux (FreeBSD, NetBSD, and Solaris).
Perform the following steps to configure a RADIUS server with Linux.
Download the package from
www.freeradius.org and follow the installation instructions at the FreeRADIUS website.
Refer to the RADIUS product documentation for information on configuring and starting up a RADIUS server.
Determine where vendor-specific dictionaries are located on the server.
user@Linux:$ locate dictionary.*
/usr/share/freeradius/dictionary.3com
/usr/share/freeradius/dictionary.3gpp
/usr/share/freeradius/dictionary.3gpp2
/usr/share/freeradius/dictionary.acc
/usr/share/freeradius/dictionary.acme
Change to the vendor-specific dictionaries directory.
user@Linux:$ cd /usr/share/freeradius/
user@Linux:/usr/share/freeradius$
Verify that the
dictionary.brocade file exists in this directory.
user@Linux:/usr/share/freeradius$ ls dictionary.brocade
dictionary. brocade
When the
dictionary.brocade file does not exist, proceed to Step 7.
Check that the contents of the
dictionary.brocade file are correct. The following example shows
the correct information.
user@Linux:/usr/share/freeradius$ more dictionary.brocade
# -*- text -*-
# Copyright (C) 2013 The FreeRADIUS Server project and contributors
VENDOR Brocade 1588
BEGIN-VENDOR Brocade
ATTRIBUTE Brocade-Auth-Role 1 string
END-VENDOR Brocade
ATTRIBUTE Brocade-Cmd 8 string
When the dictionary.brocade
file exists and holds the correct information, proceed to Step 10.
When the
dictionary.brocade file does not exist or holds incorrect information, you need to create a
dictionary.brocade file with the correct information.
Log in as the root user.
In the vendor-specific dictionaries directory, create a file named
dictionary.brocade with the below content.
# -*- text -*-
VENDOR Brocade 1588
END-VENDOR Brocade
To import the
dictionary.brocade file, add the following line to the dictionary file.
$INCLUDE dictionary.brocade
To ensure that the dictionary is loaded, restart the FreeRADIUS server.
user@Linux:/usr/share/freeradius$ sudo service freeradius restart
Configure an
Extreme user account.
Open the
/etc/raddb/users file in a text editor (the location of the FreeRADIUS users configuration file depends on the Linux distribution).
Add the user name and
associated the permissions. The user must log in using the permissions
specified with Brocade-Auth-Role. The following example configures an
account called "jsmith" with admin permissions and a password
"jspassword".
jsmith Auth-Type := Local,
User-Password == "jspassword",
Brocade-Auth-Role = "admin"
You must use double
quotation marks around the password and role.
To ensure that the changes take effect, restart the FreeRADIUS server.
When you use network information service (NIS) for authentication, the only way to enable authentication with the password file is to force the device to authenticate using password authentication protocol (PAP); this requires the setting the
pap option with the
radius-server host command.
