The following commands configure and apply an IPv6 PBR policy that routes HTTP traffic received on a virtual routing interface.
device# configure terminal device(config)# ipv6 access-list standard 99 device(conf-ip6acl-std)# permit any device(conf-ip6acl-std)# exit device(config)# route-map test-route permit 99 device(config-route-map-test-route/permit/99)# match ipv6 address acl 99 device(config-route-map-test-route/permit/99)# set ipv6 next-hop 2001:db8:0:0:0:ff00:42:8329 device(config-route-map-test-route/permit/99)# exit device(config)# interface ethernet 1/1 device(conf-if-eth-1/1)# ipv6 policy route-map test-route device(conf-if-eth-1/1)# end
