Reordering ACL-rule sequence numbers is helpful if you need to insert new rules into an ACL in which there are not enough available sequence numbers.
The first rule receives the number of the starting sequence number that you specify. Each subsequent rule receives a number larger than the preceding rule. The difference in numbers is determined by the increment number that you specify. The starting-sequence number can range from 1 through 65535, and the increment number can range from 1 through 65534.
For example: In the command below, the resequence access-list command assigns a sequence number of 50 to the first rule, 55 to the second rule, 60 to the third rule, and so forth.
device# resequence access-list mac test_02 50 5
