The software supports encrypting the passwords of all existing user accounts by enabling password encryption at the device level. By default, the encryption service is enabled.
device(config)# service password-encryption device(config)# do show running-config service password-encryption service password-encryption device(config)# username testuser role testrole desc "Test User" encryption-level 0 password hellothere device(config)# do show running-config username username admin password $6$mAog0c./JxVGu1zy$6wFogQmek0KOEgTav.0DVKXz1vRodc1UCAbipYft/DWnT5R6/Y3qpq7V3JHlhRNVtwguLgXnzdtBDKPKaXbBg/encryption-level 10 role admin desc Administrator username testuser password $6$78rhJxmF0zFKbhu4$0WvJVdRv7.ke07E5sL7m04stPw3XO9hgIxZ/xArDpKCPk6eGTlCn0YBi3xRv856hoiDv8U9eMxxi6ZZNY4CiV/encryption-level 10 role testrole desc "Test User" username user password $6$mAog0c./JxVGu1zy$6wFogQmek0KOEgTav.0DVKXz1vRodc1UCAbipYft/DWnT5R6/Y3qpq7V3JHlhRNVtwguLgXnzdtBDKPKaXbBg/encryption-level 10 role user desc User
Clear case passwords cannot be configured with Encryption Levels 7 or 10. Clear case can only be used with Encryption Level 0. In the following example,
the testuser account password is stored in clear text after password
encryption has been disabled. The default accounts, user
and admin
remain
encrypted.
device(config)# no service password-encryption device(config)# do show running-config service password-encryption no service password-encryption device(config)# username testuser role testrole desc "Test User" encryption-level 0 password hellothere enable true device(config)# do show running-config username username admin password $6$mAog0c./JxVGu1zy$6wFogQmek0KOEgTav.0DVKXz1vRodc1UCAbipYft/DWnT5R6/Y3qpq7V3JHlhRNVtwguLgXnzdtBDKPKaXbBg/encryption-level 10 role admin desc Administrator username testuser password hellothere encryption-level 0 role testrole desc "Test User" username user password $6$mAog0c./JxVGu1zy$6wFogQmek0KOEgTav.0DVKXz1vRodc1UCAbipYft/DWnT5R6/Y3qpq7V3JHlhRNVtwguLgXnzdtBDKPKaXbBg/encryption-level 10 role user desc User
password-encryption
convert-enc-to-level-10
to upgrade the passwords to
encryption-level 10 (SHA-512 hash format) making the passwords more secure. Once
this command is executed, all encryption-level 7 passwords are converted to
encryption-level 10. However, if you downgrade to a release lower than SLX
20.1.1, these accounts will not be available. This command is available only
to admin users. Any clear-text (encryption-level 0) passwords are retained
as is in the configuration database and not converted to encryption-level 10
(SHA-512 hash format). These clear-text passwords can be converted using the
service
password-encryption
configuration command.
In the following example, testuser1 has encryption-level 7, and after running the exec command, the encryption-level is changed to 10.
SLX# show running-config user | inc testuser username testuser password "cONW1RQ0nTV9Az42/9uCQg==\n" encryption-level 7 role testrole desc "Test User" SLX# password-encryption convert-enc-to-level-10 %WARN:This operation will convert all existing user passwords to SHA-512 format. However, the enc level 0 (clear-text) passwords, if any, will be retained as is in the configurationdatabase. These configurations will be lost if the system is downgraded to lower releases than SLX 20.1.1 Do you want to continue? [Y/N]y All passwords are converted successfully. SLX# show running-config user | inc testuser username testuser password $6$gV7A5lDXqcGc8/ma$MEVxe20jaBarALGhmSYw.p3oc9IXVj9xqNUGDnfNABGs.FAqwrM8EPDMvCJcZe/MsY9geY0ej01gma7mWWWTz0 encryption-level 10 role testrole desc "Test User" SLX#
The exec command password-encryption convert-enc-to-leve-10
is not allowed if
there is a configuration rollback
in-progress.
SLX# password-encryption convert-enc-to-level-10%WARN:This operation will convert all existing user passwords to SHA-512 format. However, the enc level 0 (clear-text) passwords, if any, will be retained as is in the configuration database. These configurations will be lost if the system is downgraded to lower releases than SLX 20.1.1. Do you want to continue? [Y/N]y %%ERROR: Password conversion is not allowed when configuration rollback session is in progress; Please try again later. SLX#
