When you create ACL rules, the
count parameter enables you to display counter statistics.
Enter the configure terminal
command to access global configuration mode.
device# configure terminal
Enter the
mac access-list command to create or modify an access list.
device(config)# mac access-list standard mac_acl_1
In each rule for which you need to display statistics, include the
count keyword.
device(conf-mac1-std)# seq 100 deny 0022.3333.4444 count
If you have not yet applied the ACL to the appropriate interface, do so now.
(Optional) To display ACL counter statistics, enter the
show statistics access-list command.
