TCAM profiles enable you to optimize TCAM resources according to your system requirements.
TCAM profiles other than default are supported only on devices based on the DNX chipset family. For a list of such devices, see "Supported Hardware".TCAM is used by various forwarding applications. A TCAM profile supports a specified group of forwarding applications.
For devices based on the DNX chipset-family, the following table displays maximum TCAM entries by features and TCAM profile.
* For shared limits, the TCAM is filled using first-come first-served.
** DB is shared with L2 and L3 control protocol features.
NS = not supported.
RL = rate limiting.
BD = bridge domain.
For devices based on the XGS chipset-family, the following table displays maximum TCAM entries by features. The only TCAM profile supported is default.
** DB is shared with L2 ctrl protocol, L3 protocol, and so forth.
NS = not supported.
RL = rate limiting.
BD = bridge domain.
