When a port is authenticated using 802.1X security, an IP ACL or MAC ACL that exists in the running configuration on the device can be dynamically applied to the port. To do this, you configure the Filter-ID (type 11) attribute on the RADIUS server. The Filter-Id attribute specifies the name of the IP ACL or MAC ACL.
The following table shows the syntax for configuring the Filter-Id attribute to refer to an IP ACL or MAC ACL.
Value |
Description |
ip.name.in |
Applies the specified named ACL to the 802.1X authenticated port in the inbound direction. |
ip.name.out |
Applies the specified named ACL to the 802.1X authenticated port in the outbound direction. |
mac.name.in |
Applies the specified MAC ACL to the 802.1X authenticated port in the inbound direction. |
