To suspend ACL rules, you can remove the ACL containing those rules from the interface to which it was applied. After removal, you can also delete the ACL.
device# configure terminal
device(config)# interface ethernet 5/2
device(conf-if-eth-5/2)# no ipv6 access-group ip_acl_1 in
