Many advanced ACL features are implemented per ACL rule, according to parameters that you specify.
Some advanced features also require global configuration.The following table describes advanced rule keywords for all supported devices.
Keyword |
Description |
IPv4 standard ACL |
IPv6 standard ACL |
IPv4 extended ACL |
IPv6 extended ACL |
Comments |
copy-sflow |
sFlow monitoring |
P/D; I |
P/D; I |
P/D; I |
P/D; I |
count |
Counter statistics |
P/D/H; I/O |
P/D/H; I |
P/D/H; I/O |
P/D/H; I |
drop-precedence-force |
Re-marking drop-precedence |
NA |
NA |
P; I |
P; I |
Only under default, vxlan-visibility, and border-routing TCAM profiles. |
dscp |
DSCP filtering |
NA |
NA |
P/D/H; I/O |
P/D/H; I |
dscp-force |
DSCP re-marking |
NA |
NA |
P; I |
P; I |
For routed traffic only. |
log ( SLX 9150, SLX 9250) |
Logging |
P/D/H; I |
P/D/H; I |
P/D/H; I |
P/D/H; I |
log ( SLX 9540, SLX 9640) |
Logging |
P/D; I |
P/D; I |
P/D; I |
P/D; I |
mirror ( SLX 9150, SLX 9250) |
Mirroring |
NA |
NA |
P/D/H; I |
P/D/H; I |
Effective only in ACLs applied to physical interfaces. Not supported for:
mirror ( SLX 9540, SLX 9640) |
Mirroring |
NA |
NA |
P/D; I |
P/D; I |
device(config)# ip access-list extended ip_acl_01 device(conf-ipacl-ext)# seq 10 permit host 10.24.26.145 any count log mirror copy-sflow device(conf-ipacl-ext)# seq 20 deny host 10.34.36.245 any count log mirror copy-sflow
