ACL application-targets
ACLs that you apply to interfaces or at global configuration level are summarized in a table.
You create all of these ACL types using the { mac | ip | ipv6 } access-list commands.
Table 1. ACLs applied to interfaces or at global configuration level
Target/type Description Applied from Applied with Types supported Reference
Interface
Filters all traffic entering or exiting an interface.
Interface configuration sub-modes (including VLAN and VE)
{ mac | ip | ipv6 } access-group { in | out }
MAC, IPv4, IPv6
Standard, extended
Layer 2 (MAC) ACLs
Layer 3 (IPv4 and IPv6) ACLs
Receive-path
Receive-path ACLs (rACLs) are applied at global configuration level. Their primary function is to filter CPU-bound traffic.
Global configuration mode
{ ip | ipv6 } receive access-group
IPv4, IPv6
Standard, extended
Interface ACLs and rACLs
The following table summarizes details of ACL types not discussed in the current unit, as they differ significantly from ACLs applied to interfaces and at global configuration level.
Table 2. Other ACL applications
Target/type Description Created with Applied with Types supported Notes
ACL-RL
Support rate-limiting and policing; can also protect against denial of service (DOS) attacks.
{ ip | ipv6 } access-list
match access-group acl-name
IPv4
Standard, extended
The mirror keyword is not supported.
Applied from class-map configuration mode.
IP broadcast ACLs (bACLs)
Identify directed broadcast and network-address traffic by the specified subnets, and filter traffic on the corresponding VRF.
ip subnet-broadcast-acl acl-name
IPv4
Standard, extended
Apply the ACL at device level, interface level, or VE level.
PBR
If an incoming packet matches an ACL rule, can modify default routing behavior, for example, by changing the destination port.
match {ip|ipv6} address acl acl-name
IPv4, IPv6
Standard, extended
Applied from route-map configuration mode.
Management information base (MIB)
The SNMP agent supports Get, Get-next, and Get-bulk requests for L2 ACLs on the BROCADE-ACL-MIB.
mac access-list
mac access-group
MAC
Standard, extended
Refer to Extreme SLX-OS MIB Reference.
