The SSH key-exchange specifies the algorithms used for generating one-time session keys for encryption and authentication with the SSH server.
See the online help on the device for the
complete list of supported key exchange algorithms.
For backward compatibility, the string "dh-group-14" is also acceptable in place of "diffie-hellman-group-14-sha1".
Enter global configuration mode.
device# configure terminal
Use the ssh server
key-exchange command to set the key exchange algorithm for the
server.
You can use multiple key
exchange algorithms by separating the string names with commas.
device(config)# ssh server key-exchange diffie-hellman-group14-sha1,ecdh-sha2-nistp521
Use the ssh client
client.
device(config)# ssh client key-exchange diffie-hellman-group14-sha1,ecdh-sha2-nistp521
The following ssh server and ssh client key
exchange algorithms are supported in FIPS mode:
- ecdh-sha2-nistp256
- diffie-hellman-group-exchange-sha256
- diffie-hellman-group14-sha1
The following ssh server and ssh client key exchange algorithms are
supported in CC mode:
Restart the SSH server from EXEC
mode using the ssh-server restart command for the new configuration to take
effect.
device(config)# exit
device# ssh-server restart
