Understanding the default STP configuration
You should be familiar with STP defaults before you make configuration changes.
Table 1. Default STP configuration
Parameter
Default setting
Spanning-tree mode
By default, STP, RSTP, and MSTP are disabled
Bridge priority
32768
Bridge forward delay
15 seconds
Bridge maximum aging time
20 seconds
Error disable timeout timer
Disabled
Error disable timeout interval
300 seconds
Port-channel path cost
Standard
Bridge hello time
2 seconds
The following table lists the switch defaults for the interface-specific configuration.
Table 2. Default interface specific configuration
Parameter
Default setting
Spanning tree
Enabled on the interface
Automatic edge detection
Disabled
Path cost
2000
Edge port
Disabled
Guard root
Disabled
Hello time
2 seconds
Link type
Point-to-point
Portfast
Disabled
Port priority
128
BPDU restriction
Restriction is disabled.
