Adding member bridge-domains
Follow this procedure to add member bridge domains to a topology group. Member bridge domains follow the master VLAN protocol states and also no L2 protocol will be running on the bridge domains.
Before adding a bridge domain, you should have created a topology group and configured the master VLAN for that group. The bridge-domain should not be part of any other topology group. All control ports of master VLAN must also be configured for the member bridge-domain.
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
    device(config)#
  2. Enter the topology-group command to create a topology group at the global configuration level.
    device(config)# topology-group 1
    device(conf-topo-group-1)#
  3. Enter the master-vlan command to configure a master VLAN in the topology group.
    device(conf-topo-group-1)# master-vlan 100
  4. Enter the member-bridge-domain command to add member bridge-domains to the topology group.
    device(conf-topo-group-1)# member-bridge-domain add 300
    The member-bridge-domain remove command removes an existing member bridge-domain from the topology group.
    device(conf-topo-group-1)# member-bridge-domain remove 1
The example adds 300 as member bridge-domain to the topology group.
