Configuring PW flow label on a bridge domain
Configuring flow label for pseudowire-related peer devices in a bridge domain improves load balancing of pseudowire (PW) traffic over an MPLS network.
Prior to completing the following task, the bridge domain on which flow label is to be enabled must be configured. There is an example at the end of this task that shows all the steps in order.
Flow label configuration improves load balancing of PW traffic over an MPLS network, particularly in the context of PWs that transport high volumes of traffic that are comprised of multiple individual traffic flows (for example, the same source-destination pair for a Transport Control Protocol (TCP) connection is an individual traffic flow).
Perform the following task to configure PW flow label on a bridge domain.
  1. From privileged EXEC mode, enter global configuration mode.
    device# configure terminal
  2. Enter bridge domain configuration mode. The following example shows how to enter configuration mode for bridge domain 502.
    device(config)# bridge-domain 502
  3. Enable flow label for the PW-related peer devices that are configured on the bridge domain.
    device(config-bridge-domain-502)# peer 10.9.9.9 flow-label
  4. Verify the configuration.
    show bridge-domain 502
    Bridge-domain 502
    Bridge-domain Type: MP, VC-ID: 502 MCT Enabled: FALSE
    Number of configured end-points:  3, Number of Active end-points: 1
    VE if-indx: 0, Local switching: TRUE, bpdu-drop-enable: TRUE
    MAC Withdrawal: Disabled
    PW-profile: default, mac-limit: 0
    VLAN: 502, Tagged ports: 1(1 up), Un-tagged ports: 0 (0 up)
    Tagged Ports: eth0/5.502
    Un-tagged Ports:
    Total VPLS peers: 2 (0 Operational):
    VC id: 502, Peer address: 10.9.9.9, State: Wait for LSP tunnel to Peer, uptime: -
    Load-balance: True, Cos Enabled: False,
    Tunnel cnt: 0
    Assigned LSPs count:2 Assigned LSPs:q502 q752
    Local VC lbl: 0, Remote VC lbl: 0,
    Local VC MTU: 1500, Remote VC MTU: 0,
    Local VC-Type: 5, Remote VC-Type: 0
    Local PW preferential Status: Active, Remote PW preferential Status: Active
    Local Flow Label Tx: Enabled, Local Flow Label Rx: Enabled
    Remote Flow Label Tx: Enabled, Remote Flow Label Rx: Enabled
    Local Control Word: Enabled, Remote Control Word: Enabled
The following example shows how to configure a bridge domain on which flow label is enabled for the PW-related peers.
device(config-bridge-domain-5)# vc-id 8
device(config-bridge-domain-5)# logical-interface ethernet 0/5.15
device(config-bridge-domain-5)# logical-interface port-channel 2.200
device(config-bridge-domain-5)# peer 10.15.15.15 load-balance flow-label
device(config-bridge-domain-5)# peer 10.12.12.12 flow-label
device(config-bridge-domain-5)# peer 10.12.12.12 lsp lsp1 lsp2
device(config-bridge-domain-5)# local-switching
device(config-bridge-domain-5)# bpdu-drop-enable
device(config-pw-pw_example)# exit
