Enabling and configuring R-PVST+ globally
Use this procedure to enable the Rapid Per-VLAN Spanning Tree Protocol Plus (R-PVST+).
  1. Enter global configuration mode.
    device# configure terminal
  2. Enable R-PVST+.
    device(config)# protocol spanning-tree rpvst
  3. Configure the bridge priority for the common instance.
    device(config-rpvst)# bridge-priority 4096
    Valid priority values range from 0 through 61440 in multiples of 4096. Assigning a lower priority value indicates that the bridge might become root.
  4. Configure the forward delay parameter.
    device(config-rpvst)# forward-delay  20
  5. Configure the hello time parameter.
    device(config-rpvst)# hello-time 22
  6. Configure the maximum age parameter.
    device(config-rpvst)# max-age 8
  7. Set the transmit hold count for the bridge.
    device(config-rpvst)# transmit-holdcount 9
    This command configures the maximum number of BPDUs transmitted per second before pausing for 1 second. The range is 1 through 10. The default is 6.
  8. Return to privileged exec mode.
    device(config-rpvst)# end
  9. Verify the configuration.
    device# show spanning-tree brief
    VLAN 1
     Spanning-tree Mode: Rapid PVST Protocol
          Root ID      Priority 4096
                       Address 01e0.5200.0180
                       Hello Time 2, Max Age 7, Forward Delay 11
          Bridge ID    Priority 32769
                       Hello Time 8, Max Age 22, Forward Delay 20, Tx-HoldCount 9
                       Migrate Time 3 sec
     Interface     Role  Sts  Cost       Prio  Link-type        Edge
    Observe that the settings comply with the formula set out in the STP parameters section, as:
    (2 × (forward delay - 1)) ≥ maximum age ≥ (2 × (hello time + 1))
    or in this case: 20 ≥ 7 ≥ 6.
  10. Save the configuration.
R-PVST+ configuration example
For more information about configuring parameters, see the section STP parameter configuration.
