Configuring ERP
To configure and initialize ERP using only APS you must set up one RPL owner and one or more Non-RPL nodes. The minimum configuration tasks are listed in this section.
Before configuring ERP, however, you must have already configured a VLAN and ports.
ERP supports topology-groups if the ERP interfaces are in the same VLAN
You must perform the following minimum configuration tasks for the RPL owner:
You must perform the following minimum configuration tasks for each non-RPL node:
