Configuring ETH-CSF
Follow these steps to configure ETH-CSF and verify the configuration.
Refer to the "802.1ag Connectivity Fault Management" chapter in the Extreme SLX-OS Layer 2 Switching Configuration Guide. For command details, see the Extreme SLX-OS Command Reference.
  1. Configure ETH-CSF on a physical interface.
    1. Enter global configuration mode.
      device# configure terminal
    2. Enter the protocol cfm command to enter Connectivity Fault Management (CFM) protocol configuration mode.
      device(config)# protocol cfm
    3. In CFM protocol configuration mode, enter the domain-name command to specify a Maintenance Domain, ID, and level.
      device(config-cfm)# domain-name md1 id 1 level 3
    4. Enter the ma-name command to specify an MA name, ID, VLAN, and priority.
      device(config-cfm-md-md1)# ma-name ma1 id 1 vlan 10 priority 7
    5. Enter the mep command to specify an MEP ID, state, and interface.
      device(config-cfm-ma-ma1)# mep 1 down ethernet 1/1
    6. Enter the client-interface command to specify a client interface, CSF type, and transmission period.
      device(config-cfm-ma-mep-1)# client-interface ethernet 1/1 csf-type loss-of-signal tx-period 1-minute
  2. To configure ETH-CSF on a port-channel interface, configure it as follows.
    Entering configuration mode terminal
    device(config-cfm-md-ma-ma1)# mep 1 down port-channel 100
    device(config-cfm-md-ma-mep-1)# client-interface port-channel 200 csf-type loss-of-signal tx-period 1-minute
  3. Enter the show cfm y1731 client-signal-fail command to verify the configuration.
    device# show cfm y1731 client-signal-fail
    Domain Name : md1
    MA Name     : ma1
    ETH-CSF Statistics :
    MEP RMEP MEP    RMEP   Client CSF    Transmit  Transmit Receive  Transmit Receive
    ID  ID   Status Status I/F    Type   Period    Frames   Frames   C-DCI    C-DCI
    1   2    UP     UP     1/1    C-LOS  1 minute  0        0        0        0
    2   1    UP     DOWN   1/2    C-LOS  1 second  0        0        0        0
  4. Enter the clear cfm y1731 client-signal-fail statistics command to clear the statistics.
    device# clear cfm y1731 client-signal-fail statistics
This example displays ETH-CSF configuration information and packet statistics after the clear cfm y1731 client-signal-fail command is issued.
Domain Name : md1
MA Name     : ma1
