Deleting a member port from a port channel
Follow this procedure to delete a member port from a port channel interface at the interface configuration level.
Delete a port from the port channel interface.
device(conf-if-eth-0/5)# no channel-group
The following example deletes a port 0/5 from the existing port channel interface 30.
device# configure terminal
device(config)# interface ethernet 0/5
