Displaying port-channel information
Various show commands are used to display information for a port-channel interfaces.
  1. Use the show port-channel summary command to display brief information of all port-channels.
    device# show port-channel summary
    Flags:  D - Down                P - Up in port-channel (members)
            U - Up (port-channel)   * - Primary link in port-channel
            S - Switched
            M - Not in use. Min-links not met
    Group Port-channel    Protocol   Member ports
    1     Po 1    (D)     None       Eth 2/125 (D)
                                     Eth 4/125 (D)
    2     Po 2    (D)     None       Eth 2/126 (D)
                                     Eth 4/126 (D)
    10    Po 10   (U)     LACP       Eth 2/4* (P)
                                     Eth 2/18 (P)
    100   Po 100  (U)     None       Eth 2/10* (P)
                                 		 	Eth 2/11 (P)
  2. Use the show port-channel detail command to display detailed information of all the port-channels.
    device# show port-channel detail
     LACP Aggregator: Po 10
     Aggregator type: Standard
      Actor System ID - 0x8000,f4-6e-95-9f-13-e2
      Admin Key: 0010 - Oper Key 0010
      Receive link count: 2 - Transmit link count: 2
      Individual: 0 - Ready: 1
      Partner System ID - 0x8000,f4-6e-95-9f-15-a4
      Partner Oper Key 0010
     Flag * indicates: Primary link in port-channel
     Number of Ports: 2
     Minimum links: 1
     Member ports:
       Link: Eth 0/9 (0xC012140) sync: 1
       Link: Eth 0/10 (0xC014140) sync: 1   *
  3. Use the show port-channel number command to display detailed information of a specific port-channel interface
    device# show port-channel 10
    Port-channel 10 is admin down, line protocol is down (admin down)
    Hardware is AGGREGATE, address is 00e0.0c70.cc07
        Current address is 00e0.0c70.cc07
    Interface index (ifindex) is 671088650
    Minimum number of links to bring Port-channel up is 1
    MTU 1548 bytes
    LineSpeed Actual     : Nil
    Allowed Member Speed : 10000 Mbit
    Priority Tag disable
    Forward LACP PDU: Enable
    Last clearing of show interface counters: 00:29:09
    Queueing strategy: fifo
    Receive Statistics:
        0 packets, 0 bytes
        Unicasts: 0, Multicasts: 0, Broadcasts: 0
        64-byte pkts: 0, Over 64-byte pkts: 0, Over 127-byte pkts: 0
        Over 255-byte pkts: 0, Over 511-byte pkts: 0, Over 1023-byte pkts: 0
        Over 1518-byte pkts(Jumbo): 0
        Runts: 0, Jabbers: 0, CRC: 0, Overruns: 0
        Errors: 0, Discards: 0
    Transmit Statistics:
        0 packets, 0 bytes
        Underruns: 0
    Rate info:
        Input 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate
        Output 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate
    Time since last interface status change: 00:29:09
