Link aggregation overview
Link aggregation enables you to bundle multiple physical Ethernet links into a single port-channel, providing enhanced performance, redundancy, and availability.
We also refer to port-channels as link-aggregation groups (LAGs). A LAG is considered a single link by connected devices, the Spanning Tree Protocol, IEEE 802.1Q VLANs, and so on. When one physical link in the LAG fails, the other links stay up. A small drop in traffic is experienced when one link fails.
When queuing traffic from multiple input sources to the same output port, all input sources are given the same weight, regardless of whether the input source is a single physical link or a port-channel.
The benefits of link aggregation are as follows:
Each LAG consists of the following components:
Two LAG types are supported:
