Replacing a master VLAN
For replacing the existing master VLAN of a topology group, use the master-vlan command with the new master VLAN.
To avoid temporary loops when the master VLAN is replaced by another VLAN, the following recommendation is made:
If the recommendation is not followed, and a new master VLAN is configured with a different convergence, the configuration is still accepted.
The master VLAN replacement is accepted if both the old and the new master VLANs are spanning-tree disabled.
