Shutting down MSTP
Follow these steps to o shut down MSTP either globally, on a specific interface, or a specific VLAN.
  1. Enter global configuration mode.
    device# configure terminal
  2. Shut down MSTP.
    • Shut down MSTP globally and return to privileged EXEC mode.
      device(config)# protocol spanning-tree mstp
      device(config-mstp)# shutdown
      device(config-mstp)# end
    • Shut down MSTP on a specific interface and return to privileged EXEC mode.
      device(config)# interface ethernet 0/2
      device(conf-if-eth-0/2)# spanning-tree shutdown
      device(conf-if-eth-0/2)# end
    • Shut down MSTP on a specific VLAN and return to privileged EXEC mode.
      device(config)# vlan 10
      device(config-vlan-10)# spanning-tree shutdown
      device(config-vlan-10)# end
  3. Verify the configuration.
    device# show spanning-tree
    device#
  4. Save the running configuration to the startup configuration.
Shut down MSTP configuration example
device(config-stp)# end
Shutting down MSTP on a VLAN is used in this example.
