Configuring additional MCT cluster parameters
The SLX-OS device has additional cluster commands with default values. You can change the parameters for these commands in cluster configuration mode.
Peer Keepalive
The peer-keepalive feature helps in distinguishing interface failure and cluster peer node failure, and takes action accordingly. An out-of-band keep-alive session is recommended between the nodes. This helps to distinguish peer-interface failures from peer node reboot. Different actions can then be taken for these peer-interface failures.
The keep-alive session has 2 flavors:
  • Auto keep-alive session (default)
    • Does not require any explicit user configuration, and is run in the management VRF. The management IPs of the two nodes are exchanged once the cluster session is established and an out-of-band keep-alive session is started between them.
  • Manual keep-alive session
    • A source interface with IP and destination IP can be specified to be used for keep-alive session. This can be in any VRF. These IP addresses cannot match the peer IP and source IP used for the CCP session to ensure proper out-of-band functionality.
The peer-keepalive role determines the node‘s behavior when the ICL goes down, but the MCT peer remains up.
When a keep-alive session goes down but the CCP session remains up, the cluster continues to operate in regular mode. No traffic flow change is observed. This mode is not recommended because there is no peer-link protection. If the CCP session were also to go down, the behavior would be same as a peer reload; both nodes would keep the clients up and become the DF for all VLANs/BDs.
Use the peer-keepalive command to configure the peer-keepalive mode on a node, as shown in the following example.
device(config)# cluster leaf1_2
device(config-cluster-leaf1_2)# peer-keepalive
device(config-peer-keepalive)# role primary
Configuring peer-keepalive destination
Use the peer-keepalive destination ip command to overwrite the default keepalive session with the configured session between the specified source and the destination IP address
device(config-cluster-leaf1_2)# peer-keepalive destination 10.20.161.158
Moving the traffic from an MCT node to the remote node
Use the shutdown {all | clients} command to move all the traffic on the node to the remote MCT node by disabling the local client interfaces administratively. Use of the all parameter will shutdown the MCT peer and clients.
device(config-cluster-leaf1_2)# shutdown clients
