SLX-OS MCT control plane
  A TCP session using port 8179 is
		established between the nodes using the peer IP and the cluster source IP.
	 The control plane session requires a direct link
			btween the nodes (peer-interface) to be operational.The control plane session is used to
			exchange the following information:
				- MCT client discovery
- MCT client VLAN/BD configuration
					information
- Route exchanges – MAC, MAC/IP,
					IGMP
- Keep-alive peer IP in auto discovery
					mode
- Other required state/signaling
					for protocols, such as PIM, and mac-move detection
 A cluster control protocol (CCP) session is used to exchange MAC, MAC/IP and IGMP
			routes between the MCT peers. A cache is created within the MCT process to hold MAC, ARP
			and IGMP routes. For the VLANs/BDs that are shared between the MCT nodes, all local
			routes received from L2, ARP and multicast modules are stored in L2RIB and advertised to
			the MCT peer. Routes in L2RIB have the following possible sources:
A route selection algorithm is run to determine the best route and download only that
			route for installation in hardware. L2RIB also generates a sequence number for the
			routes and passes this on to BGP for MAC mobility and MAC dampening purposes. L2RIB does
			not include a dampening logic and relies on the MAC move detection feature to detect and
			mitigate layer-2 loops.
		Local routes from l2/arp/multicast modules are cached and advertised to mct-peer and BGP
			based on vlan/bd extension. Similarly remote routes from MCT peer and BGP are cached in
			mct process and advertised to L2/ARP/Multicast processes for hardware programming.
