Naming an Ethernet Ring Node
From within the ERP configuration shell, you can optionally name an ERN with a meaningful name by means of the name command.
The name must be 31 alphanumeric characters or fewer, and can use the "underscore" and "dash" special characters. For example, to assign the name "major-ring-vlan100" to an ERN with ID number 100, enter the following:
device# configure terminal
Entering configuration mode terminal
device(config)# erp 100
device(config-erp-100)#
device(config-erp-100)# name "major-ring-vlan100"
Use the no form of the command to remove the name.
