Setting the ITU-T G.8032 version number
You can configure the ERP configuration to use G.8032 version 1 or 2. The default value is version 2.
The following example configures Version 1.
device# configure terminal
device(config)# erp 1
device(config-erp-1)# version 1
Use the no version command to clear the configuration, restoring it to the default value.
You can view the version by entering the show erp command. The version appears on the top line directly after the ERP ID.
The following example displays information about all ERP instances, including the version.
device# show erp
ERP 5 (Version 2) - VLAN 6
Erp ID  Status     Oper              Node          Non-revertive      Topo
                   state             role          mode               group
5       enabled    Idle              rpl-node      disabled           -
Fast         Ring         WTR        WTB        Guard      Holdoff    Msg
convergence  type         time(min)  time(ms)   time(ms)   time(ms)   intv(ms)
enabled      Major ring   5          5500       1500       0          5000
Raps-default-mac   Parent-ring-erp-id   Raps-propagate-tc   Mel-Config   Mel-Oper
ON                 0                    OFF                 2            3
I/F     Port       ERP port state   Interface status   Interface type
L       eth0/4     forwarding       normal              non-rpl
R       eth0/7     blocking         normal              rpl
